Propwash
- 11:41 AM
- Oct 29, 2009
- Island of Misfit Toys
Hey fella's,
The bird recently seemed to develop a little hick up. Every once in a while, when cruising at about 30mph (right at 1400-1500 RPM) the car will have a slight miss. It doesn't stick around or repeat, doesn't buck the car, is very light. It might happen 3-4 times of a half hour of cruising around. I pulled the dist. cap and the arc strikes are at the very edges of the contacts in the cap, and looking at the top of the rotor, it looks like the arc did some wandering. One thing I did notice is that the shaft has some sloppy up/down play. Like 1/4" inch sloppy.
I'm just starting to troubleshoot this. This is something that has started in the past month. To me it seems like a definite ignition issue. There is no other sign of this issue at any other RPM or while giving her the berries through the 1400-1500 rpm range. The distributor is from 4 seconds Flat, custom curved and phased for this motor, and is set at 22* initial and 36* total. It was dyno tuned for this timing going off torque/HP curves, vacuum and Exhaust gas temps.
Any ideas out there?
