- 3:02 AM
- May 14, 2011
- On the Ridge, TN
I'll try to make this as brief as possible...
Engine: '75 440 block, 906 heads, forged internals, darn close to stock specs.
Car: 1968 GTX 4 speed with 3.55s.
Cam: 509 purpleshaft.
Ignition: Mopar electronic ignition coversion kit, orange box.
Carb: brand new Holley 3310 vac. sec.
Fuel tank, fuel pump, lines, etc. are all new.
Exhaust is big-assed Hedmans and 3" all the way back with Flowmasters (yeah, I know, but that's what was on it when I got it).
I have "inherited" this car from the mentioned deceased former owner, so there's a lot of mysteries being figured out as I go, but she's a really pretty, very solid car now and worth the effort I think.
Motor was built by a (now deceased) lifetime Mopar dealer mechanic; no further info is therefore available as a result. Motor looks for all intents to be stock configuration, nothing tricky.
The car has been built back from pretty much scratch; was a former field find on which all rot was replaced with clean metal.
I have had it running several times and it starts and idles once warmed up on its' own.
I have about 8hg vacuum @ idle and the thing LOVES lots of initial timing, currently at 12BTC.
Today was the first time in decades the car has actually seen the road. Very momentus occasion, to say the least; very nerve-racking taking it out....
Problems: There is an off-idle stumble that clears with more throttle.
In addition, the carb surges when you just try to maintain a set speed that also eases with a quick little dab of additional throttle. Happens in any gear, any speed.
In other words, it's time to set the carb up for this combination to get good driveability and smoothness. This is my first Mopar project in decades as well and I'm no Holley expert, so I'd appreciate a sort of "Holley for Dummies" bit of help here.
In fact, I'm betting there's been a few billion folks that came before me running the 509 in a 440 and using the Holley 3310, eh?
Thanks in advance!
Thanks in advance!
