Wookie316
Hi guys. Have an issue with a MP aluminum head (P5153524) and need advice and or opinions on what to do. I only have about 600 miles on this engine and have had an external coolant leak that has been like a needle in the haystack to find. It has always had coolant on top of the oil pump (B) engine. I thought it was possibly the head gasket itself because the coolant was running down the edge of the block/head also. It has the Cometic C5461-040 gasket installed. I pressured the system up and could never find a leak when cold. Only seems to leak when hot. I found a loose WP housing bolt and thought I had found my problem. Anyways I went to a cruise last night and when I go home I could smell antifreeze, so upon inspection I once again have coolant on top of the oil pump. Looking around a bit I can see a coolant streak on the D/S head at the front. I had noticed it before, but thought it was blow back from my electric fan. I had a leaky water neck at one time which has since been repaired, so I now know it is not blow back from the fan.
So, I am now thinking I either have a porous head or a micro crack that is opening up when the engine gets warm. If you look at attached photo, look close at the “o” in Mopar. This is where I believe it is coming from.
Now being this is obviously a manufacture issue and not an abuse or improper install issue, I am wondering who I may be able to contact to possibly get some sort of warranty out of this? Of course it is past a year since I purchased the head and I know if I go back to where I got it, they will give me the line that it is past the time limit, but perhaps someone has a contact to an insider in the Mopar chain that may take a look at it and help with the purchase price of a new head? I know it is a long shot and it probably won’t lead anywhere, but it never hurts to inquire?
I am already prepared to the fact that I am probably going to end up having to buy a new head anyways, but thought I’d get opinions on some ideas I’m kicking around?
1. Will a guy be able to pull the head and have someone successfully weld the spot? I am guessing they would need to grind a groove in it to have the weld hold. This is a long shot but I thought I could swap the heads side to side then the repair would face the back on the P/S.
2. If I ultimately have to by a replacement head, do I by a single MP head for that side, or do I look at swapping them for either Edelbrock performer RPM’s or 440 Source Stealth’s?
3. Since it’s an external leak, any ideas what I could put on it to get me through summer? Don’t want to pull apart till winter if I don’t have to. I’m thinking about cleaning the surface and trying an epoxy of some sort to perhaps seal it up. It’s not leaking bad, just enough to be a major annoyance.
So if any of you have some advice in to regards to what to do, or what you would do if you were in my shoes, I’d sure appreciate it! Thx in advance for all your responses. Enjoy your weekend.
