Why oils aint oils
natas33
11:52 AM
A
So a guy on a board once got me thinking about how modern massive turbo diesel trucks can withstand so much crap hauling thousands of lbs down the road, and car oils get toasty after a few thousand miles of street driving.
One day I began using Fuchs heavy truck 15w.40 diesel oil in all my cars. The engines have never ran smoother, more powerful, and I swear this stuff doesn't need changing for 15,000+miles in a passenger car engine :laughing6:
Seriously, can they get away with selling the same oil for a rig designed to haul loads making 2000 ft/lbs torque? They only sell what they can get away with.. to a degree.
15w/40 diesel truck oil is the best thing your street or race engine ever had. sure you might lose 10hp versus a thinner weight oil.. but the money you'll save in oil changes, after several years you can buy a new engine :frog:
If an automobile had the same size pan and capacity as a diesel engine, I would expect it to go a long time between oil changes..................................MO
The oils are better just old rotella before they changed the label.. is not 2014 rotella... that was the $hit 5years ago....
But.. the diesel oil in the same automobile.. (that was previously using car oil) ..... seems to be lasting much longer
I used to run Rottella in my car until they started removing ZDDP from it. Now I use just plain Valvoline 10-40 with a ZDDPlus additive in it. I used Rottella for many years in my trucks. How do you tell how long your oil last? .............................MO
I run Castrol Edge in my vehicles. I change my filter at 5k and oil every 10k. Probably could go even longer.
After using only synthetics once a year and nearly 200,000 miles, my wife's 1991 Plymouth Laser still has honing marks on the cylinder walls and no trace of wear. Then it broke due to a faulty (Contitec) timing belt.
