WTB Fan pully for a 318 ?
PFG MOPAR
2:04 PM
Grants Pass OR
Inexpensive, please ?
Mike.
A replacement aluminum pump was installed ..
:thumbsup:
cast iron or aluminum water pump? they are different depths
a/c?
hello I might have one in my pile of parts that I have in the garage. I,ll take a look soon.
Also might want to tell us if you need single groove or dual groove.
pulley
I have a few Big Block single groove fan pulleys and single to four groove crank pulleys if you need some. PM with e-mail address for pictures.
Still need a pulley, the aluminum one was too short.
It was about 2 1/2" and I need one about 2 7/8" !!?
It lined up with the outside groove on the crank pulley, I need it to line up with the Inside groove.
:BangHead:
Anyone?
Thanks,
Mike.
:BangHead:
Anyone?
Thanks,
Mike.
if you have a cast aluminum pump and no A/C the pulley is 3" . it looks like this. its the only one cone shaped single groove. I have one but im not sure where it is. this set is on Ebay
Generally the small block pulley depending on a/c or cast iron or year the most common pulley is 6 1/2" diameter and 2 5/8" depth.... small block.... the5 3/4"x 2" depth big block a/c pulley is on my '67 318 w/ac to line up with a bullet gearheads 3grove crank pulley and 68 up SFI ballancer.... I have shimed out the accessories and am in the process of buttoning up that soon... e bay has a bunch of mopar pulley and a Chevy pulley will work or a jaguar.... measure and stand back and look for the line ups.... sometimes a flat washer here and there will help shim.
