70 RR
Back in April, I decided to build a big stroker motor. I went 60 over on the pistons with a 4.5'' stroke. I wanted to reuse my six barrel carbs and intake but many people tried to talk me out of it. The easy thing to do would have been use a Super Victor manifold and big Dominator 4 barrel carb but I held my ground! I said screw the 4 barrel, I want the six barrel.
When all was said and done, that motor was way too much for that little Holley 350 CFM in the middle so we decided to take a Holley 500 and modify it to fit that middle slot. WHAT AN AWESOME SETUP! I owe all the credit to Gary Box at Box Performance Columbia Station Ohio.
Here are some pics of the work. A side by side with a Holley 350 left and a 500 on the right. The transformation took a little over two hours. Took some parts from the 350 and used them on the 500 and did a little cutting and grinding to the 500 carb body. Also had to drill a hole and install a tube to draw vacuum to open the outboard carbs.
