can i us a ls t56 for my consvertion
jubin
6:40 PM
miami fl.
Can I us an ls t56 for my conversion. If so what part do I need?
What conversion? You most likely can. Not sure which engine you are swapping, but the bellhousings can be changed depending on application
Its is all in the car is a 72 roadrunner with a 400ci and a 8³/4 . What is happening is I am have trouble bleeding the slave cylinder. When i strat to bleed it the peddle never gets hard and it lecks the fluid out from the bottom of the bell house. I am using one from a 2000 ls z28. I wonder if I need to us a different slave cylinder. That's all I need once that done Ican go ahead and fit the road. Does someone have I idea what my be happening.
If the slave is leaking i would think you need a new one. Or a line is loose and leaking. Sorry to say the trans sounds like it needs to come out to inspect
I am using a quick time bell housing meloud flywheel I made my own cross member from the factory one 28 spline 11" gm clutch but I cannot bleed this thing. I am wondering if it is extending to far and not getting to the P-plate. If I put the car in gear and hit the key it moves???????????????
Man I have taken this thing out so many times It comes out by it self LOL. I just need to now if I need a a different slave cylinder or a idea on how to bleed this
I thought you needed to use the Ford style T56 because of the input shaft but I could be wrong, you might want to talk to American Powertrain.
I am about to pull all of this out and go back to my 727 and start driving my car again. ;-)
LOL, I know the feeling, if you do I'd be interested in the T56 haha.
This is what i used mopar 747
QUICKTIME-RM6077
MOPAR Big Block 383/400/426/440 Bellhousing to T56 Chevy LS-1 Transmission
If the slave cylinder is anything like the Viper T-56, you will need to put a spacer behind the slave to get it closer to the pressure plate. The slave is likely over-extending and allowing fluid out. I don't know what the measurement will be but the throw out bearing should be touching the pressure plate and the slave should be around the middle of its travel while at rest. I hope this helps.
