fmahannah
1963 Dodge Polara Max Wedge Tribute
- 8:36 AM
- Sep 25, 2014
- Dahlonega, North Georgia
Edelbrock 800 on a torker II, sitting on a 413 bored 60 over, 440 ported heads, adjustable drivetrain. Only thing I know about the cam is it is mopar, purple shaft?, and lumpy.
This is on a recently purchased 63 polara 500, pushbutton auto, AC.
Previous owner did not drive it hardly at all the last 2 years. Runs, idles, and drives .... but exhaust will burn your eyes.
Idle mixture screws have no effect. Idle is at 750 even with them screwed all the way in. Removed and shot air in there, no difference.
No obvious signs of flooding other than fumes. Hooked up vacuum guage and only getting 4-5 lbs at idle. Picks up normally at all throttle levels.
Knew this was too low at idle even for a lumpy cam, contacted owner and when he had the carb tuned he had 7-9 lbs and added a summit vacuum pump
to run the brake booster, which works well.
Step down spring was already yellow, tried blue made no difference in idle. Changed back to yellow.
Even stranger, timed vacuum port on carb reads identical to the full manifold vacuum port 4-5 lbs. I thought the timed port should read
zero until throttle is open? Is it possible that a vacuum leak would do this? I always thought a vacuum leak at the carb would increase idle
speed because of extra air drawn in, but that is not happening. I can idle down to 500 and it keeps running and does not stall in neutral.
Before I tear the carb down for a rebuild and new gaskets, has anyone ever run into this before or are there anythings outside the carb that I can check first.
Previous owner has vac advance disconnected and all in at 34-36. Never saw this done before.
Thanks for any help or ideas. Want to take car to a cruise in on Saturday but don't want to fumigate everyone there
