I bought this tach on eBay to put in the console of my 64 Sport Fury. I knew it looked a little rough on the outside, but the face with the lettering was very good.
Even if I needed it to be repaired, I got this because it is original. However this baby is sealed up tight -- no user serviceable parts. The outer metal rim is like crimped on over the case which is slightly flared. Has anybody taken one of these apart? I was thinking about cutting the case around the circumference, but even then I couldn't get to the glass. The console already has a clear lens so I may not even need the glass on the tach.
While I've got your attention. Do you know where the two studs are connected? Does the case act as a ground?
