am3rican
I took the dash apart trying to figure out why none of my dash lights work. Gauges work fine (except tach). Dome light works when I turn the dimmer switch full on. I also broke two pins in the dash connector. I was expecting this though. Several more pins were loose. I will solder later. All fuses checked out okay.
Questions
- How do I test if the dimmer switch is faulty?
- As you can see from the pictures, I'm missing several bulb sockets. Should there be a bulb and socket in every empty spot?
- Can someone give me a rundown on how to check the tach? I have mopar performance electric ignition.
Questions
