Difference Between Quarter Panels
tqfastfish
6:53 PM
VT
We are restoring a 1973 Charger In the shop and It needs quarter Panels. AMD doesn't make any for it but they do make them for a 1971 charger..
The question is .. Would we be able to use 1971 charger quarter panels on the 1973 charger?? IS the only difference the marker Light?
Thanks a lot
The lower body line in the front of the car is different between 71-72 and 73 you might look and see but would assume that's the big difference.
Wheel well opening is larger on the 73/4.
are you sure of that ? I know in front they are but I have my doubts on rear. Outer wheel housings are mentiones interchangeable with some minor mods.
BESIDE THAT, the quarter glass opening is WAY different... that makes also a dif body curve and height
Upper body line is more pronounced on 73/74 as well.
Sherman/Goodmark made a full length patch panel at one time.
Sherman/Goodmark is the same piece as the one from Tabco, they just tack more onto the price.
Too bad you're so far away, I've got a driver's side one to sell.
