Bigcountry
Hello 747, thank you for this very useful post. I want to put the same setup in my 69 Coronet and will watch your progress with much interest. Do you plan on using the Viper shifter and stick or something else?
Oh ok, that's a good idea for making that adjustable, I just wasn't/still not sure how compatible the oem clutch pedal was with the hydraulic MC. Does the pedal bolt right up to the pushrod no problem? Sorry for the noob questions just trying to clear myself up lol
Looks like the weekends here! Wish you luck everything goes as planned this weekend Devin!
Not to speak for 747 but knowing him I believe he plans to fabricate something himself that will have a pistol grip. I'll either find a pistol grip that will work or modify one so the layback doesn't interfere with my bench.
I did find another thread doing some research where a guy is using a Pro 5.0 shifter mechanism for an '03-'04 Cobra. The assembly bolts right in place of where the Viper mechanism did and his pistol grip bolts right to it.
Thank ya Goon. I too want to use a pistol grip or a factory looking ball. Was wondering because I am using a bench also.
Hey MrSpeedfreak keep on asking, your just taking the questions right out of my head. I'm paying close attention too. Thanks everyone for doing the trailblazing for us!
BTW...does anyone want to buy a 727 with 69,000 miles on it? lol.
Hey Speedy - I've got some of the "trail-blazing" documented on my build thread, but I'm not as far along to have to "get-er-done" right now. It looked to me like I needed to relocate the hydraulic master a little further to the left then where I originally set it up for my 5-speed. But now that I'm changing over to the Challenger tr-6060 6-speed, I'm considering swapping over to the same master that the Challenger used so it'll mate up nicely with the hydraulic slave cylinder that I've go inside my transmission . . . that seems to be the best option ( in my opinion ).
now, "where" it will need to be mounted on the pedal is still an unknown, as I was also thinking about how the travel would have to match - but, once again, I'm not there yet ! ! But, I'm sure that it can be moved up or down to get the travel to match the master, be smooth, and not require one to be a weight lifter to depress the clutch ! !
I'm thinking of starting another thread for my tr-6060 install, so as not to interfere with 747 Mopar and Goon on their modifications . . . but I'm following this, for sure !
Lol! Hey hey hey, I never said I lacked the skills to make it work. But in defense of my stupid question, I've never installed a 4 speed mopar pedal setup to know what the linkage looks like compared to the Wilwood pushrod. Although I shoulda noticed Wookie's was an oem pedal. Ah well :head_smack:
Think I'm gonna get the cheaper Wilwood pedal setup just to screw with ya now haha!
I had to shave both the head of the bolt through the brake pedal and the head of the bolt on the clutch rod that attaches to the pedal so they would clear each other.
Mine is unique to this though because the original pedals were butchered when the manual conversion was put in. I have since repaired all of this as best as I can but I had to think outside the box on a couple things.
Wow, diving right in man! A lot of good info there and thanks for the pics of the pedal setup, either way I end up going, I'm not too worried at all now, seems either one should work well assuming USA is liking his setup. Got paid yesterday, hopefully selling some parts today, and I'm officially saving up for my T56 haha :waiting:
Really liking this thread and all I've been learning here lately too, great idea and thanks again
Hey Dev,
Sorry for the delay in posting/asking this; it relates to stuff from the first page.
Just a thought; when I installed a Lakewood scatter shield (on my Vette) the flange area around the perimeter was fairly tight and socket head bolts, having a smaller head diameter, made it easier to get the bolts in and secured. I've never used a Quick Time (heard their awesome quality) so I can't say "fer sur" but maybe the situation is the same?
As for the "spacer" with a lip you're talking about fabbing up; maybe I'm missing something in the pictures you posted but I'm not getting it, so can you explain in a bit more detail why you need a spacer?
Just as a side note to all you guys talking about pedals: I received my Wilwood setup (Throttle/Brake/Clutch - floor mount) and the quality is f'n superb, so if you're looking for a set of hanging/swinging pedals I wouldn't be afraid of going with Wilwood. Believe it or not I got mine on Amazon for a real aggressive price and $0 freight.
Thanks,
Bob
Feel free to post pics of your pedal setup. As for the spacer I guess I should have waited to be sure it would even need one before saying anything. What I am referring to is getting the stroke for the internal hyd set right, when adapting a tranny that isn't made for the application you have to make sure all the tolerances are inline. The bell housing can only put the input shaft where it needs to be in the pilot bearing leaving the internal hyd wherever it falls. The instructions in the Keisler kit called for 1/4" - 1/2" clearance between the throw out (internal hyd) and pressure plate fingers to prevent overstroking it or having pressure applied while at rest. So to answer your question, if it's within the specs (I'll check with McLeod and others for the specs) then there will be no spacer but if it's say an 1" away from engaging than a 1/2"-3/4" spacer will be needed (going by Keislers specs) to move it out closing the gap up. Hope that explained it but if not I'll get to that within a week or 2.
Your right about the Quicktime brand, really nice looking pieces. The socket head bolts to me are just a bad idea on things that need to be tight or in areas that require universal joints to get to. They take deeper tools to get a hold of and if you can't get a socket on them your stuck with an allen wrench, I guess I just find the traditional hex head has more flexibility as far as tools and tight spots. P.S the bell housing seams to have plenty of clearance for whatever I put in it.
Ha,ha, i'm confused now.lol. The Wilwood pedals I saw at the link in this thread seemed to be for racing applications. It also looked like the brake and clutch fluid reservoirs were inside the cab and not in the engine bay. Does that work on our old cars? Is there room under there to do that? Cause if so I would like it to not have the MC hanging off the firewall. Do they work on street applications?
