benno440
Hey guys,
Been tinkering around with my timing and carb tuning and have a feq questions/thoughts.
505 stroker
ported stealth heads
ported RPM intake
pro systems 1000cfm carb
MSD 6al, blaster 2, and pro billet dizzy
Set my initial at 20* with 34* total, started to get detonation and starter drag.
backed it off to 18* no more detonation but feels a little sluggish, have the 2 light blue springs in the advance ( NO VAC ADVANCE) so its all in around 2400rpm.
carb tuning i dont have a good enough vac gauge so i used the demon carb tuning book from 4secondsflat.
where you set your 2 primary corner screws around 2 turns out, and the secondaries at 1.5 out, then put your idle where you want it, then tap the pump arm if it gets better adjust to suit and worse adjust to suit, i have all 4 corners now on the idle i need and when tapping the pump arm the engine does not die or rev up so supposedly it is pretty close to being spot on.
but after all this when going for a drive it seems a bit sluggish and when cruising at low rpm then plant it it doesnt quite stumble or hiccup but it slugs down if that makes sense.
could this be more timing orientated?
I am not sure if you guys know much about pro systems carbs but they have no vauum ports in them and they are built specifically to your engine specs and then tested, jets etc do not need to be changed unless you are less than 1 turn in or 3 turns out on the 4 corner screws supposedly.
505 stroker
ported RPM intake
