jenkins71
Hi guys. I got my 440 block back, and am having another "what would you do?" question.
The block was honed and check out. I am now at .030" over and ready to start building. The question is, what pistons and heads do I use?
I gave the machinist the L2266's (flat-top) that came inside the motor, as well as a set of used L2295's (domed, hi-comp) that I picked up for cheap. He checked the clearance of the piston sets to the wall, and they were as follows:
L2266: .003
L2295: .007
Both are within spec, but the 2295's are possibly a little on the loose side.
I want a good compression ratio, which is why I got the L2295's to replace the flat pistons. I have a set of good 452 heads ready to go, but they have big 96cc chambers and would have a really low CR unless I used the L2295's.
So, considering...
Should I re-use the L2266's and swap the 452's out for a set of closed-chambered heads? There is a set of 915's near me for $600. Assuming they have 78cc chambers, I would have a CR of 9.05:1 using the composite gaskets I have. If I switched to a steel shim gasket, I could get 9.5:1.
OR, do I continue with the plan and run the L2295's with my 452's? This would cost me another $200-300 as I would have to get the pistons balanced to my crank. This would end me with about 10.5:1 compression ratio.
This motor is for use in a 71 Charger. I want to build it for torque and mid-range power. I want as much power as I can get, for the least amount of money. Occasional trips to the drag strip, but mostly a daily driver powerhouse.
Thanks for your advice!
L2266: .003
L2295: .007
So, considering...
