Help decoding 69 superbee fender tag.
Kjs427
4:59 PM
Fremont
some of the codes come up blank so i thought i would see what you guys come up with.
V8X END
J25 L31 M21 M46 R11 V1X
A01 A04 A05 A62 B51 G33
F5 F5 H2G F8 422 352175
E63 D32 WM21 H9E xxxxxx
Thanks!!!!!!
V8X END
Thanks!!!!!!
so F5 repeated so just all green car if you put f5f5 in same bubble is shows question marks. also A01,V1X show blank and then comes the simulated 1/4 scoops code M46 and no ram air or bulge hood just plain flat hood???
E63: 383 4BBL
D32: HD A-727 Torqueflite
WM21: Coronet, Medium Price Class, 2 Dr. Sedan
H9E: 383cid, 335HP (Magnum), 1969, Los Angeles CA
xxxxxx: Sequential Production Number
F5: Exterior Color, Medium Green Metallic
F5: Interior Color, Medium Green Metallic
H2G: Upper Door Color ?
F8: Dark Green Metallic
422: Build Date April 22nd
352175:
A01: Light Package
A04: Basic Group
A05: Protection Group
A62: Rallye Instrument Cluster
B51: Power Assist Disc Brakes
G33: O/S LH Remote STD Mirror
J25: 3 Spd Variable Wipers
L31: Hood/Fender Mount Turn Signals
M21: RF Drip Rail Moldings
M46: Simulated 1/4 Panel Scoop
R11: Music Master Radio AM
V1X: Full Vinyl Roof, Black
V8X: Transverse Stripe, black
END
The first F5 would be the lower body color, and the 2nd one is the upper body color. These codes would not match if it was a two tone car. The "G" in H2G is would designate green interior, and the F8 would be darker green upper door panels. V1X is a black vinyl top, and A01 is an interior light package. These are my guesses without digging out my white book.
ok thanks, and the hood would it just be a flat one??? or ???? what would of came with side scoops option?
your S Bee would have came with the power bulge hood. the fender mount turn signals are listed. no ram charger hood w/ fender mount TS's as the RH side is not visable with scoop on there.
Makes perfect sense thanks for all the info guys!!!
Question for 69 Hemi
My 69 bee has n96 and m46 but fender tag only shows m46. I have no build sheet. Was the n96 added after factory or is it possible it came that way but didn't show on fender tag? Someone told me fender tag does not always show all the options. Your thoughts
