Need to open up my outside rear wheel well a little
SUPERSTOCKRACER
11:28 AM
Oblivion
Any tricks to gain about 1/8" on the outer wheel lip. just got new wheels with a 5" backspace and it's so freakin close but not hitting, inside has plenty. I think going around a turn, its going to rub.
I have a set of wheels with a 6" b/s.
:sign19:want to grab some sushi, come on over for Valentines Day and help me roll my wheel well. :pumping heart:
Just in case it don't work out with Bob....
:eusa_doh:
You will never be able to roll it with one of those rollers. Ask me how I know. They work good on those japanese tuna cans though.
I did the baseball bat deal many years ago with a wood bat,
I used the big end on a 68 Charger, it compressed in the tire pretty well
& rolled the lip by about 1/4" up actually, it worked relatively well,
I didn't see any noticeable distortion on the outside either...
IIRC I started on the front side of the well wells, shoved the bat in & rolled the car backwards,
tire grabs the bat & rolls the lip "with a little pulling up/or pushing down, force on the bat handle"
then repeated it from the rear side of the wheel wells & rolled the car forward...
IIRC I overinflated the tires too, so the bat didn't just sink into the soft side walls of the slicks...
sorry that's all I remember doing
good luck
IIRC I started on the front side of the well wells, rolled the car backwards,
good luck
how long did it take? How many bat rolls? I want to make sure i'm doing it right.
or use a cut-off wheel, in a peanut or die-grinder, air or electric
& cut the lips excess & file the edges & tape then off then paint them so the won't rust
also works
I saw a YouTube version that used a phone book and the existing tire to help move the panel . . . interesting technique . . . might want to look it up ( similar to a baseball bat )
I've got a couple used aluminum softball bats that I would donate to you for this as they no longer pass the roundness test at the games ( LMAO )
man it was years ago,
IIRC a couple of passes each way
I do remember I just went slow, the cautious approach
IIRC you can shove the bat up father {farther, not father} if you think it's too fat or something,
use a narrower part of the bat, I do remember having to push down or pull up on the bat thou,
which I don't/can't remember thou...
IIRC you can shove the bat up father if you think it's too fat or something,
You realize that this post you just put up is very disturbing.
that should have said farther not father {like I posted}..LOL
yep I'm a little twisted too...
