In a MP electronic conversion there isn’t a direct distributor to coil connection, conversion may have been reversed. Post a picture of the distributor leads or what’s under the cap.The coil negative is hooked to the wire off the distributor, nothing hooked to positive (because I don't know what hooks to it)
If it’s not obvious, that’s not a distributor for a Mopar electronic ignition conversion. To use that distributor, the single lead from the distributor connects to the negative side of the coil and one of the pictured ring terminated wires is likely the positive side of the coil. To identify, either power up ign. run and check for something less than battery voltage or ohm it out to one of the ballast resistor terminals, opposite ign. 1 on the ballast resistor.
