furyus
- 4:04 AM
- Jan 5, 2010
- weeki wachee, florida
Getting your engine angled down more is way easier than fighting those Allen bolts.
Oil pan resting on the drag link? Might need to drop it.
Shorten those pins and round the off the ends. 2" will allow the input shaft clear the crank flange and spline from the disc I believe.
Looks like someone failed to get the bolts out of the adapter before. May have to drill the heads off.
Thanks for the idea of the board and straps---Why didn't I think of that??..................................MO
Not sure because of the angle of the picture. Are you using the clutch disc alighnment tool to center it? Does the tool fit into the pilot bearing without to much or two little clearance? Got all the clutch cover bolts in the correct holes and tightening each one a little at a time ? with all the cover bolts tightened evenly, the tool should slide back out without binding.........................MO.
by some coincidence I'm going through my trans. right now. the answer to the countersunk shifter pad screws is a small Oxy Acetylene tip heat up around the screws and they will come out like butter. put some sheet metal above the trans to deflect any heat from getting to your carpet through the shifter hole.
while trying to stab the trans in to the bell housing have someone slightly depress the clutch pedal while you position the transmission.
Here are some pictures, I couldn't find any when I was looking.If anyone cares.
Hi there D575, how would depressing the clutch pedal make the stabbing easier? asking cause I don't know
/Linus
/Linus
It allows the disk to float , Be sure you have the input shaft started in it though. Might have to put it in gear and turn the output shaft while doing it. I'm not too good at explaining things in writing , maybe someone else can make it . make sense.. :sideways tongue:
