Paul_G
- 6:24 PM
- Dec 24, 2013
- Surprise, Arizona
I installed a Summit brand, which is an AEM A/F ratio gauge in my 72. Now that it is working I am trying to get the carb dialed in a little better. The readings bounces around a lot, so the numbers I am posting are in a range.
My set up is a 360 engine, stock stroke, iron head, mild head porting, Holley SA 670, RPM Air Gap intake, long tube headers, cam unkown, 2500 stahl, 391 gears. On the dyno it has proven to be a torque motor. 255Hp with 360 TQ at the wheels. Ignition timing is 30° base, 34° total all in by 2000 rpm. If timing is a factor? This engine loves lots of static timing. I had an off idle stumble until I brought the timing up.
What puzzles me is how the jetting is laying out so far. Ideal A/F ratio is 14.7:1 for gasoline right? I have been reading up on how to use the A/F gauge. This is what I should try to achieve; Idle 12.5 to 13.2, Cruiseing 14.7 to 15, Max Power 12.6 to 12.8.
Column 1 is where I started with the A/F gauge. Carb was jetted up from stock. Column 2 is jetting back to stock for the 670. Column 3, leaning the jetting started to improve the ratio.
In column 1, you can see low speed ratio is a little rich, light throttle is way lean, full throttle is rich.
In column 2, Stock jetting, it leaned out across the board.
In column 3, I leaned the secondary side only, left the primary alone. All the numbers changed again. Light throttle leaned out, full throttle leaned out slightly. It looks like the primary wants to be richer yet, secondary leaner. The primarys and secondaries look they will end up being very close in jetting? If not the same, or larger primaries?
After the jet change in column 3 the cars pulls noticeably harder at full throttle.
Column 1 ..................Column 2 ................Column 3
Jetting 67 p 70 s ..................65 p 68 s .................65p 67 s
idle @ 18" vac 12 .............................12 ...........................12
40 mph 14 .............................14.5 to 15 ................12.9
60 mph 13.8 to 14 ..................15.9 to 16 .................15.5 to 16
light throttle 16 .............................14.5 to 15 .................15 to 16
full throttle 11 .............................11.5 .........................11.8 to 11.9
