chad
I got a holley 750 on my 383. The motor has the purple 484 shaft in it, ported 906 heads, its a solid 10-1 motor. Set the timing at 36 total. Now this carb has always been funky, I had a buddy of mine redo it. He was supposed to be a carb guru, but now the carb doesn't respond a whole lot with the idle air screws. I tried setting it with the vacuum guage to no avail. The funny thing with this carb is , if I set the idle speed a ,900 rpms and go for a ride. The rpm will shoot up to 1200-1300 at a stop light unless I ride the clutch a little and load the motor and push clutch back in it will idle a 900 rpm fine. When I am shifting gears the rpms don't come down. Almost like it has a vacuum leak. But it doesn't. But now I noticed I unplugged the vacuum advance line and there is some fuel coming out of it. Could it be he has the gasket in the mettlering block backwards ? Also if I turn the idle speed screw its really touchy. A quarter turn make a 300 rpm change
