cdr
hey GOON that is flywheel #'s
here is the link to wallace http://www.wallaceracing.com/et-hp-mph.php
Howdy y'all
Hydrogoon said you had a Procharger discussion going on here, and since we don't have a dedicated forum for Protouring I've been keeping my ideas a bit to myself so the purists don't burn any crosses on my lawn or anything.
This will be a pretty long post so bare with me - just wanted to set the stage for what I'm building.
The engine
The engine is a 440 stroked .030" with hydraulic lifters and a 850 double pumper on it. Everything else about it is uncharted territory. Engine dynoed to 475 and runs smooth and pulls hard. The guy I bought it from has the build chart somewhere but I haven't been successful getting hold of them yet.
The plan
Since I know nothing about the engine I'm guessing it has pretty high CR which I don't want to boost too much, the plan is to run E85 which is widely available here in Socialist State of Sweden. Even though I hate the fuel and the governments way of enforcing it on us - it does come with some good characteristics. I used to run a Dodge Magnum SRT8 with a D1 blower on it using E85 with really good results. I like the configurability of modern cars - so I quickly decided to go all in and go EFI and FI. Then I realized that I'm not filthy rich and decided to do EFI this season and FI the next. E85 fits that route pretty good as well since car will run fine without the blower, and it will be a pretty easy task to tune it for the blower once I get that. I'm still kicking myself for selling the D1.
The parts
I want a high ram intake, and I want a forward facing throttle body. That leaves me only with Edelbrock ProFlo XT bundled with a generic 95mm TB. However I'm having some concerns when it comes to the Edelbrock ECU why I've started to investigate options. Right now I have Holley and XFI Sportsman on my shortlist - both of them (at least after this summers software upgrade for Holley) can handle a GM Flexifuel cell which is important to me. I don't want to end up towing the car or sitting at the gas station tuning it because I ended up at the one place that didn't have E85. So Edelbrock + Holley = Unique combination. I'm such a pioneer lol.
Fuel side must be upped from my initial ideas - running boosted E85 requires a lot of fuel. My choice will be injectors from Injector Dynamics in the 1200cc range. Pump from Aeromotive with AN12 feed and AN10 return. Regulator from Aeromotive as well
I'm still looking at getting another D1 unit and this is the part where I haven't got that far in my research. It will definitely be an intercooler and I think there's room.
So, that's my story right now - I'm happy to chime in wherever I can and I'll bookmark this post. Hope that you guys can answer some of my questions too when I get that far. I have a front suspension to build too![]()
Yup you got the mini-monster haha and I thought my P1SC looked huge when I first saw it lol!Here are the specs on my D1X for anyone interested:
Procharger D1X Specs:
Max CFM: 1900
Max Boost: 32psi
Max Impeller RPM: 58,000
Outlet ID: 2.62"
Outlet Hose Diameter: 3.00"
Impeller Exducer Dia: 6.6"
Inducer Diameter: 4"
Inlet Hose Diameter: 4.25"
Compressor Housing Diameter: 9.75"
Internal Step up: 4.44:1
My understanding is the D1X was the last D Series before stepping up to an F
On the brackets note - you guys don't happen to have any CNC drawings do you ;)
Your car is bad@ss dreadlock! And the magnum, too. And yeah I'm just now diving into the efi project, here's a basic outline of what I have planned for my entire setup
- .030 over 440, balanced forged bottom end. Unsure of compression but a couple friends more knowledgeable than myself are thinking it's somewhere between 9 and 10.0:1, so that will have to be figured out before I get to the procharger. But I'll most likely be going with a set of Eddy performer rpm heads with flatout spacer gaskets if necessary.
- Still unsure on cam, might go with a custom ground engle, but I did have an interesting conversation with meep-meep while he was up here last weekend about the Mopar 528 purple cam I noticed had a 112 lsa. So I think that may be an option as well
- Procharger P1sc, 8 psi, front mount intercooler (lucky Chargers have acres of real estate between the core support and grille assembly), 12 rib pulleys if I have room, 6 rib if not. fabricating my own driver's side mounting brackets, probably with help from some cardboard templates from Goon
- Dedicated blower pulley piggybacked off the front of the factory crank pulley, hopefully retaining power steering with a remote-reservoir mini pump. No A/C except speed and vent windows lol
EFI:
- Megasquirt ms3x ecu
- Edelbrock pro-flo intake and fuel rails
- Ebay 92 mm throttle body
- oem 55 lb/hr Shelby GT500 injectors with injector dynamics extension hats
- IAC, TPS, IAT, MAT sensors all standard chevy LS equipment
- Corvette zr1 3 bar map sensor along with the ms3's 2.5 map for altitude correction
- '01-04 Jeep straight 6 Cam Synchronizer sitting in a bushing I'll machine myself
- Ford EDIS-4 style 36-1 trigger wheel and crank position sensor, trigger wheel modified and welded to the back of the factory crank pulley, fabricated bracket for the sensor
- Chevy D585 "truck" coils
- Obviously o2 sensors on the header collectors
- Custom fabricating my own carbon fiber instrument cluster with Speedhut gauges, to make room for adding boost and A/F
- Aeromotive 13301 regulator
- Aeromotive Phantom 340 in-tank pump in modified factory charger tank
- 3/8 sending and return lines
- various AN fittings and everything I'll need to plumb and wire this whole shebang haha
