- 10:34 AM
- May 14, 2011
- On the Ridge, TN
Hey guys-
Next issue on the GTX comeback happened recently.
Details again, quickly:
440, supposedly rebuilt by another (now deceased) about 5 years ago but recently just started driving it, so basically still breaking in.
Has the bigger hydraulic purpleshaft, stock 906 heads and stock short block.
Engine has been a bugger to dial in the Holley 750 vacsec 3310 carb. Has Mopar electronic ignition conversion kit. Finally got it running halfway decent and took it to its' first show.
Problem...
Symptoms: Started burning oil out the drivers' side, blue smoke out the tailpipe on that side.
Audible (but not a total) miss on that side as well, running sorta rough.
Pulled new spark plug, plug is wet with oil on threads and electrode but not fouled yet.
Pulled valve cover and started wiggling rockers, seemed ok.
Started pushing down on pushrods and lo and behold, the #3 intake pushrod is EASILY plunged down by fingers. I can feel the plunger of the lifter go down against VERY little resistance, then bottom in what I assume to be the bottom of the lifter.
Audibly, too - you can hear and feel the lifter plunger bottom out.
Captain Obvious question:
Am I to assume I just have a failed/collapsed lifter (in which case, I'll replace all the dang things) or should I worry about more than that?
Thanks in advance as always!
Ed
Problem...
Ed
