Jegs cam for 440
CarKnockerJim
9:01 AM
Martin, TN
has anyone ran the Jegs 282/292 .465/.488 cam in a 440??? I wanna put it in my smogger 1975 440....its a 114 separation angle so it should keep cylinder pressure up.....any thoughts. I have a 750 speed demon, torkerII, factory stall, 3.23 suregrip 9.25 rear..
Looking for a good sound and pull on a shoestring budget.
I had a Crowler "Monarch" back in the day, 280 / 460 lift. Had that 383 in the mid thirteens. Nice sounding idle, good pulling thru the mid range. Works well with a stock converter.
I'm looking for something like you're talking about. Do you have the Jegs part number?
I'm not sure but if you do it please post the results. I may go that route with a 440 I have.
That cam isn't much different than the larger Summit cam that a lot of people have used with good luck.
the jegs cam is the same as the summit 6401. i have a 6401 in a stock 440 and really like it. smooth idle and a bunch of torque; very nice driver. i wouldn't use stock springs with it, in fact i'm sure lopo springs will coil bind and don't think the red hipo's will work either.
http://www.jegs.com/i/JEGS-Performance-Products/555/200166/10002/-1?parentProductId=
here is a link...
Im not really wanting a smooth idle....what springs would you recommend?
