1911pro
Well I had a hell off a day trying to put a new gas tank in my 70 Roadrunner. I have a Right Stuff tank and AMD straps, bolts and OER neck. The bracket on the neck would not work because it sat to low so I removed it. The straps have no bend at all at the filler end ( completely straight) and will barely reach the bolts ( green colored reproduction studs)hanging at the differential end with no way to even touch a tread with the nut. Does any one know if the factory straps had a bend and drop down at the filler end? The ones I have are straight with not enough length to try and put my own bend in it. All parts are correct part # for a 70 b body and the tank is pushed back at the filler tube end as far as it will go. Tank it pressed up against the trunk floor with a reproduction mat between them. Hhhheeeelllppppppp. Thanks.
