74Beeper
The cam is the only thing making that combo not work. Big cams get you big power, but they are not conducive to street use at all. That particular grind is not a street friendly grind either which hurts even more. IMO - wrong cam choice but definately makes a great dyno number. You have to treat it like a superstocker...lol. Evacs will help assuming the exhaust is free flowing enough, otherwise they will help the idle because of the vacuum leak plugging, but you'll start pushing oil out various weaker gaskets. The Edelbrocks are not calibrated to work with that low of an idle signal. That's why there's no response to the idle screws. Get a modern Holley based carb or carbs for it and you'll be able to tune for it.
600psi over the nose... you should be testing your valve springs once a year at least too. That cam will eat springs in an engine that idles like in a street car.
I appreciate all the advice... I have been talking to the guys at Lunati and they are recommending their biggest Voodoo solid roller.
It's spec'd out at...... 285/293 Advertised, 255/263 @.050 & .600/.600 lift with LSA/ICL @ 110/104
I will be putting this cam in this winter when i park her for the year. It will give me something to do during the long cold North Dakota winter.
But first i need to get all this crap installed!!!! I tend to go a little overboard with the online shopping when i'm out on the platform....haha
