74 Roadrunner
Sooopr
8:48 PM
Oceanside NY
Hi I'm Dave. Love the Mopars. Looking for some help on a few topics. First off what is easiest way to get to the Instrument cluster bulbs on a Ralley Dash. I want to put LED. I'm thinking remove the cluster. Any help on this?
Also I have a sunroof that didnt work when I got the car. I fixed it but I am not able to get the headliner cover back on. What am I missing?
Welcome! sorry I am no help to your problems
Welcome! Nice looking car!!! As far as changing the bulbs, it can be done with the cluster still in the car, just a lot of time on your back crammed under the dash, and changing bulbs is tricky that way, may have to do some by feel. You can remove the cluster, but you will have to take out the radio first, then disconnect the wiper and headlight switch harnesses, drop the steering column by loosening the support bolts, and then you can partially pull it out, but will have to disconnect all the other wires. I would try doing it from underneath first, the bulb connections are not too bad to remove, but overall its gonna be a bit of time either way.
Hi and welcome to the site stick around and enjoy.:headbang:
Welcome Dave. Sweet 74.
Thanks. enjoying it!
Thanks. was just there drinking Tank 7
Appreciate that. Thanks!
Thanks for the advice. Probably gonna pull the cluster. Just too big and no flexibility anymore!
OK. Pulled the cluster and installed the lights. Looks awesome and I didnt even clean the lenses yet. I used white led's.
Another LED night photo
1974 Roadrunner at night with LED Dash
