Markzilla88
Hey guys. So my original problem was that my starter switch on my 73 Charger 318 was bad. Car would crank all day long by turning the key, sometimes it would start, sometimes it wouldn't. You would have to find that "Sweet Spot". However, Car would start every single time if you jumped the started solenoid under the hood.
Went and got a new Ignition starter switch, pulled the column apart and reinstalled. I placed the red and black wires on the new switch into what seemed to be the correct ports, red to red and black to black, and the two red wires coming from the key lock went into the same ports they were installed on with the old harness. I went to go start it after, and got nothing. Not even a crank of the engine this time. I tried starting the car by jumping the starter solenoid and again it worked.
Here are some things I noticed from the car after installing the new ignition switch.
-Dome light dims when trying to start by key
-Voltmeter drops to the "D" position when trying to start
-Blinkers no longer work
-Horn works, but it sounds like its struggling badly and the voltmeter drops significantly when you hit the horn
Im looking for any help on this to resolve my issue because I am beyond lost. Many thanks in advanced
