kjalltrac
I´m looking for some input on this subject.
This is my combo.
stock bottom low comp 440
comp xe284 hydraulic cam
dur @50 240/246
lift 0.507/0.51
lobe sep 110
452 heads, stock valve size, back cut. shaved 0.04, pocket ported.
8.5:1 comp
Edelbrock rpm manifold
1 3/4 headers
3" dual exhaust
msd 6A ignition
19 deg initial, 39 deg at 2000rpm
Stock weight Belvedere 1964
727 trans with Transco tf2 kit
3000 stall converter
8 3/4 rear with 3.73 gears
will use 26" slicks at track.
I have an A/f meter for tuning.
( also have a lot of holley jets, gaskets, cams, etc.)
The car is mostly used as a weekend street car and do a little racing but not as much as I want to. (lack of tracks and events here)
I guess I want the best of two worlds here, good street/drag performance and pretty good mpg.
I do drive the car pretty far on vacation to car meetings and tracks.
I have tried a holley 850 dp, It felt the strongest with this carb but had terrible mpg on road trips and was not "low cruise friendly".
I´m currently running a edelbrock hp750. Tuned it with the leanest rods and jets in the edelbrock tuning kit, but still a little to rich at cruise, slight bog when flooring it from under 1500rpm.
What do you think about the quick fuel 780 vac sec (hr-780-vs)?
Maybe the edelbrock 800 thunder series can be a option?
This engine will probably see a 100-150hp of nitrous in the future.
This is my combo.
dur @50 240/246
lift 0.507/0.51
lobe sep 110
8.5:1 comp
1 3/4 headers
3" dual exhaust
msd 6A ignition
