skyman51
Unless someone pulled it out of a truck. The only way to know for sure is to check out the internals, especially the valve reliefs on the cylinders.
Either way its NOT a matching numbers car and keep that in mind when you're talking price with the guy. Its either a true '62 max wedge block with a set of aluminum heads and all the rest of the goodies, or someone cloned one using a truck block and a bunch of aftermarket parts. What carbs are on it? Edelbrock or original AFB's? Do the heads have true Max Wedge ports and is the intake an original or reporoduction. Lots of stuff to check before you pay top dollar. But if it checks out (and even if it doesn't) its a good find.
A real max wedge has an oil pan unique to that motor and was not installed on anything else. All max wedge blocks have AAQA embossed on the front of the block on the drivers side.
