mr. b
your super bee looks great I love the color keep us posted
Made some progress everyone. Found out in this process that there's always 1 little part that will stop your progress, for a week or so at time. One headache I would like to pass along might not be a help to some of you experienced rebuilds but r a novice like myself it drove me crazy until I figured it out. While rebuilding my column I replaced the turn signal switch. When testing the dash I couldn't get the turn signals and hazards to work properly. If I disconnected either the hazards or turn signal flasher then one system or the other would work ! Drove me crazy and I couldn't find any thread on here with the same problem. I called Mega who supplied the switch but they said they hadn't heard of any problems with the switch and promptly sent me another for free. After trying the second switch with the same results I then grabbed a column from another 70 b body and compared the wiring. The switch problem came down to the wires installed backwards on the top and bottom of the Hazzard block part of the switch. Drilled the rivets out, swapped the wires, rerivet and amazingly it works properly !View attachment 294403
WOW!! I wonder if that's what my problem is...i have the same one in a '71 GTX. i have an intermittent hazard flashing crazy issue after i let off the brakes, and there isn't even a relay on the hazard circuit!!
what should the color order be??
sjd
Just flat out gorgeous
