Bruzilla
I was wondering about the line cut into the damper shown below. What does it represent? I'm trying to find timing marks on my damper and that's the only mark I see.
I like to paint the recess in that line white, so I can see it easier.
I just line up #1, and if I'm 180* off, I "just" pull the distributor and put it in 180* around.
Lots easier than pulling and resealing a valve cover and/or relying on others.
So with the line and 0 deg mark on the tab lined up, the rotor should be pointing at the number one cylinder of the distributor cap regardless of which one is marked 1 on the cap itself?
IMO, if you follow the service manual using stock items, I think you'll find #1 on the distributor always ends up in the same spot. In that case it should assure you the necessary clearance for the stock components. Aftermarket distributors may or may not have the same pump drive to rotor index. Different heads or intakes can also affect clearance.
Do yourself a favor on the damper. Once you determine exact TDC and mark it, add a mark to the inner hub that coincides with the TDC mark on your outer ring. It will be a quick reference to any slip.
I agree.Something I did that I really liked was after confirming tdc I bought a timing tape (have to get the right one for the diameter of balancer) and installed it lined up with the 0 mark on the cover. It just makes reading a lot easier with the yellow tape and bold black print?
