I want to set up my 71 Charger to be flat-towed by my 93 Ram Van
jenkins71
3:31 AM
Queens, NYC
Hi Guys--
Title says it all. I move around a lot. And I'm tired of doing it like this:
Or worse, with the little two-wheeled dolly.
I want to set up my Charger to be flat towed, behind my 93 Ram Van with 360/a518!!! Meaning, all four wheels on the ground. I see guys with RV's towing their Jeeps all the time, and figured it must be a Jeep-only thing.
But then I saw a guy towing a Kia Soul, and another guy towing a newer Mustang! So it must be able to be done.
I don't mind adding some things to the chassis of the Charger. I can weld, do whatever. I want it to be a system, ready to go for easy transport. Does anyone have experience with this? Or thoughts?
Thank you!!!
I built a tow bar and attaching bar from some c chanel inside each other to make a box, for my 67 R/T to tow it to San Antonio raceway when I lived in Corpus Christi. I had to disconnect the driveshaft and attatched it to my driveshaft loop. I did have to drill 4 holes in the bumper though, but I was looking for another bumper anyway. You will just have to figure out where to attatch it to the car. I can remove or install it in under 10 minutes.
Cool. Got pictures?
I don't mind drilling on to or even welding on to my bumper.
Also, I want to add that I am totally unfamiliar with flat-towing vehicles, so any pointers on how to do it safely would be helpful.
My charger is a 4-speed standard, does that mean I can leave the propshaft attached?
Thanks!
With a tow bar, your turning radius suffers greatly.
With a dolly it suffers some but not as much, however you run the risk of creasing your door/fender with the dolly fender.
Backing up is nearly impossible with either, but almost completely impossible with a dolly.
back in the 70's I towed with a tow bar to the track all the time , I got tired of taking off the drive shaft so I made some tow hubs for the rear . take off the rear tire , bolt on the tow hub, put the tire back on and take off, only trouble I had flat towing is when the rear car was in lose gravel or sand the the front tires wouldn't follow.
tow dolly pics
Here are some pictures of the set up I made. It tracks straight behind my Nissan Frontier. Just don't crowd anyone in front of you.
I just used parts and pieces of stuff I had lying around, all but the receiver for the ball. Did you notice the distributor hold downs and rod caps? I use those for added security so that the bolts won't pull through the bumper. I also run a 20 foot tow strap across the truck frame and back to the cars strut rods just for insurance. I hope this is useful.
Send me your trailer and I will send you a tow bar in return. Bar is 5000 lb. rated. You will have to make mounts. Second thought if you are still on the east coast I can purchase a trailer localy for what the gas would cost .
I don't have a trailer, likely, never will. The bar seems so much simpler and easier.
I think you can rent a tow-bar that attaches to your front bumper , from U Haul....................MO
Also check craigslist and local junk yards.
I had a tow bar thrown in free with some parts I bought and another one thrown in with a truck I bought.
I bought a dolly off ebay from a local seller for $375.
Keep in mind that eventually (possibly the first time) you clamp a bar to the front bumper, you will likely scratch the chrome.
I shaped 2 hard urethane spacers to go between the bumper and the bar that mounts to it. The insulators also keep the bar in the correct position/angle. You can see the top of them if you look closely at the pictures. These prevent scratching the bumper.
I have flat towed and used the dolley. Now-a-days I own a flatbed:glasses13:
U-Haul hasn't rented out towbars for nearly 25 years, due to liability issues. I used those quite a bit in the 1980s...only real requirement was that you had a stout-enough front bumper on the towed vehicle, PLUS you never, ever want to flat-tow a front-engined car without an engine in place! Squirreliest damn thing you ever want to do, behind putting a car on a trailer backwards (same result).
U-Haul DOES sell a bolt-on tow bar assembly. My son works for U-Haul, so that is how I know.
I wouldn't trust bolting any tow bar just to a bumper. I'd be afraid the bolts might break, as they aren't made for holding the weight under a tow.
For a few bucks more than a dolly,you can rent an open trailer:blob1:
True, but if I am going to tow a Jeep or something with a bolt-on steel front bumper (most pre-1990 cars and trucks), a bolt-on tow bar is a cheap alternative, plus I don't have to turn it in. And yes, the dolly is only twelve dollars cheaper per day than the trailer, if the rental is local.
You better also consider the rear axle before ground towing. Sure - Grips should not be towed long distances on the ground and speeds are recommended at 45 mph.
Disconnect your drive shaft and tie it up so the trans doesn't get tatered by lack of oil.
I know that you are trying to save bucks, but it would be better in the long run if you just bought a trailer, since you say you move around a lot. I have seen some scary **** when using a dolly. I won't ever use one. I tried the flat towing as a young man. I felt it was very unsafe. Also, all the crap thrown out by the tow vehicle will smack your car right in the face.
