Overdrive Transmission installation for my 65 Belvedere
65RoadRacer
4:04 AM
somewhere else
We went to Silver Sport Transmissions for a PerfectFit Kit for my Belvedere. This is the A41 4-speed overdrive based on the 4L60E GM transmission. Although they have a listing for the 62-65, we had to use a 66-70 kit, and make a couple of simple modifications.
Here is the installation article: Silver Sport Transmissions: Shifting Classic Mopars Into Overdrive
looks awesome, ive been looking at their Tremec 5 sp for my 65 post, Passon is currently out of their over drive 4sp gear sets, and Silver state offer financing which is cool when your already thousands of bucks in a resto.
So what did the kit cost you? I saw that some thing included you already had, I also have a ratchet shifter and aux cooler. Thanks for the info.
I think this kit runs about $7k altogether, but considering it includes everything, that's about what you'd spend anyway, not counting your man hours for fabricating all the parts. The really nice thing about this kit is that if you later go to a big block, you just need to swap the bellhousing, which you can get from Silver Sport.
With a near 4 MPG increase, that's enough to save me almost 5 gallons every tank full of gas (based on driving 64 miles further on a tank of gas).
its sure good to have the overdrive,saves driving at at 2800-3000rpm to do 65mph,instead 1700-1900 rpm ,I am building a ford AOD for my 505 1972 road runner built to handle 700 HP it uses JW powerglide bellhousing,JW billet 4340 flexplate and chev style converter.have to cut ford bell housing off and jw bolts to pump and centres on a machined pump housing.it uses stage 1 rasbestos frictions 6 forward 4 intermediate ,7 direct.has 4R70W gearset 2.84 ,1.55/1.00/0.70 OD,has manual Valve body with overdrive on solenoid switch.this is a fully hydraulic trans no computer.check out silverfox transmissions in Missouri,he builds 950 HP handling ,FB performance in new York builds 1200HP handling.this trans cost me $5800AUD with conWP_20150101_08_34_34_Pro.jpgWP_20150101_12_19_34_Pro.jpgWP_20150101_11_41_24_Pro.jpgWP_20150101_13_33_36_Pro.jpgverter
There's not one single thing a person can do to improve the drivability of these classic cars that compares to an overdrive, congrats. This will result in racking up more miles, comfortably cruising at freeway speeds and helping out the wallet at the same time. Best decision I ever made.
Research it well before you jump in. I hate to constantly be the one putting the TKO down but I feel it's my duty to share my experience so nobody makes the same mistake. First off unless you don't care about the tranny pointing down creating pinion angle issues, fan shroud clearance problems and headers hanging lower you'll have to cut the cross member. 2nd is the tranny itself does not shift very well for a performance application, more like a truck. These are known issues and they very well may have fixed the shift issue so just do your homework. I have no experience with the Passon tranny but my understanding is its basically all fit into an 833 case so fitment should be of no issue.
This is the one big problem with Keisler, and since I've started talking to Silver Sport I've learned that pinion and driveshaft angles are the one huge area that everyone at SST wanted to fix. One of the guys told me specifically that they wanted this fixed, especially with Mopars, or they didn't want to be a part of this. The owner of SST and I have become friends through this endeavor and I can tell you with full certainty that they are committed to making these Tremecs fit properly - and the right way. Anyone considering a Tremec in their Mopar, I urge you to contact them and let them know this is a concern, and let them tell you what they've done to remedy this problem. Even Sam at TTi Exhaust mentioned this to me about the Keisler AOD, but SST is re-engineering a lot of kits to fix this, as well as to put the shifter in the proper location, too.
As for my OD, I'm getting about 60-65 miles more per tank full of gas... and I've racked up about 5-6k miles each year, so this will definitely be worth it. I think with some fine tuning of my EFI and keeping the speeds about 65 I might get a little better than 17 MPG... we'll see. But I do love the way this trans works, and the adjustable shift points and firmness are great to have.
OZMercury... what a conversion... that's a lot of work you're doing, but sounds pretty cool. My gearing is at 3.06, 1.63, 1.00, 0.70. I thought the low gear set I had on my 727 was low, but this one was even lower. It's pretty quick off the line, and where I used to get a chirp in second before, I'm now getting a little sideways kick and some 2nd gear spinning. It's definitely nicer to cruise at 70 and see just over 2100 RPM instead of nearly 3400.
That's great to hear, my biggest beef has always been the false advertising calling it a bolt in unit so the fact that they acknowledge it is a big step in the right direction.
Yes, they have videos now that they put out talking about how important it is to have the right driveline angles. This video shows what is considered when designing a kit.
[video]https://youtu.be/tv8mbMl41jw[/video]
OzMercury:
Holy crap! That transmission sounds like a wild assortment of parts! Ford AOD in a Powerglide case? That is unusual! All this to fit in a Mopar??? Crazy!
