Identify/Source Separate Part
IceBee
8:20 AM
Europe
Hey,
I'm having some problem with my horn and after dismantling the steering wheel/column I ended up needing a new contact roller switch made in brass.
So it's a small brass pin with a wheel in it. It's located in the picture where the black wire goes in underneath. The whole Signal Switch kit can be bought from YearOne, but rather expensive. Does anyone have a suggestion where to find the brass wheel pin separate?
https://www.yearone.com/Product/chrysler-b-body/fd47801#
I don't think you'll find it separately, but someone hanging on to a junk turn signal should be able to hook you up. The little plastic cancelling arms are what usually break.
I have those PM/message me
If you want new, I see them listed in the Classic Industries catalog. pre 1970 are $114.99. Post 1970 are only $49.99.
Thanks. It's the pin itself I'm looking for. Trying to avoid getting a full kit for a small brass part..
