- 3:38 PM
- Mar 28, 2014
- South Louisiana
Ok. Because of the way FBO designed my distributor, for my motor, I have to connect a constant manifold vacuum source to the FBO distributor's vacuum advance can. I found one under the center carb, where the choke vacuum diaphragm is connected. I assume that there are no other constant manifold vacuum connections, (are there?) and that I will have to use a Y to have both lines connected, unless I can connect the choke vacuum diaphragm to the ported metal nipple higher up on the center carb?
The other issue is my 440 now has gone from 850 rpm idle to 1100 rpm, and I don't see any way to adjust the idle down further. The "anti run on solenoid" is no longer active (it used to work) and the screw that would normally contact it doesn't touch it. Maybe I have too much fuel "leaking" in through the outboard carbs? They are "fully closed" as far as the linkage goes, and I don't know how to close them further even if they are slightly open or allowing fuel to come in. I could REALLY use some help as tomorrow is my last tuning day before leaving Friday afternoon for a 2 1/2 hr each way trip to Mopars at the Battleship in Mobile, AL.
The distributor is designed to have 18° advance at idle with no vacuum, the constant manifold vacuum source is designed to add 12° advance at idle (full manifold vacuum) and 16° mechanical advance which is all in at 3,200 rpm. So at WOT I have 34° total advance all in at 3,200 rpm, but if I lift or am at part throttle, the constant manifold vacuum kicks in additional advance.
