Mike Gaines
- 2:01 AM
- Apr 17, 2014
- Ahwahnee, (Fresno) California
Give me some feedback on this:
Most guys I talk to say that the ideal water temperature to launch the car at is 140-150 degrees...not "heating up" the motor to 180 degrees.
Pull into the water box at 125 degrees then after heating up the tires the water temp will be around 140-150 when staging....Cooler motor makes more power...
COMMENTS AND INSIGHT WELCOMED AND NEEDED.
THANKS
PS: After installing my Meziere HD Hi Volume Electric Water Pump and with my giant BE-COOL Radiator with twin fans I can now get the water temp down to 125 degrees between rounds even on a 100 degree day. I turn off the motor and run the fans and the electric water pump to circulate the water thru the radiator and block again and again.
THANKS
