Mike Gaines
- 10:21 PM
- Apr 17, 2014
- Ahwahnee, (Fresno) California
Is anyone of my Racing Pals out there running a "deep grove" pulley on their alternator.
If so...can you post a picture of your alternator with that pulley installed with the belt in place.
As I have outlined on a previous post I am having trouble fliping my alternator pulley belt.
I installed a Meziere electric water pump and have only a belt running from the crank to the alternator.
The crank pulley and the alternator pulley are dead on lined up. I installed a "new" belt for this setup after I installed my new Meziere electric pump and took off the belt drive water pump. That belt flipped off on the first run.
That belt sat down into the alternator pulley where the top of the belt was exactly level with the top off the V of the pulley, but it flipped it. That belt was a "cheap" $5 belt at Oriellys.
I then bought the $19 Gates belt which seems to be much stiffer in construction but the top of the belt actually sits about 1/64" of an inch above the V of the alternator pulley. Havent made a run yet with this belt.
I was hoping that one of you guys had actually found a source for a "deep grove" alternator pulley and could post a picture of it and where you got it.
Thanks, Mike
Thanks, Mike
