wsutard
I was driving on the free way the other day, 85 degrees out, temp got to about 195. Parked, went to dinner, couple hours later I headed back out. In the middle of the freeway on ramp the engine died then came back on causing huge back fire and a buck. I was forced to continue on to the freeway. Nothing happened for another 1/4 mile. Then the engine died and came back on again, bucking, multiple times. Then it stayed on for another 500 ft.
At this point I was looking for the nearest exit, which just so happened to be up a frigging hill. I hit the exit with a little speed, got to the middle of the hill and the car died. Tried to turn it back over, but it wasn't catching. Was stopping traffic so I had to roll backwards on to the shoulder.
I could tell that it was trying to fire when I was engaging the ignition but as soon as I let off the ignition it would die. Looked under the hood, thought that maybe it was due to heat (it wasn't). Called the flat bed, two hour wait, in 85 degree heat blazing sun. I waited 5 min and decided to try to turn it over again, nothing.
The fact it wanted to start when I had the ignition engaged made me try something. This time I engaged the ignition then instead of letting go of the key I kept enough pressure on the key to be right at the point where the next bit of pressure would engage the starter.
The engine stayed running, and running good. As soon as I released the pressure from the key it would die. Luckily my wife was in the car. I started it again, kept the key pressure with my right, steered with my left and had my wife throw the gears. (1st to 3rd works surprisingly well)
About 5 min into this, and going downhill, I decided to take the pressure off the key to see what would happen. Nothing, ran fine the 10 minutes back home.
Anyone have any idea what is going on?
