crahill39
I am going with all Disk brakes by Wilwood and will be switching to manual vs power. With the engine build in progress, we will lose some vacuum which impact the power brakes. From what I researched, the manual master cylinder setup should work just as well.Are you going to all 4 disc brakes? this weekend I removed the cobbled together mess that was the stock proportioning valve and the SSBC adjustable one (which leaked a tiny bit), and replaced it all with a wilwood adjustable one. Braking is VASTLY improved. I was having a problem where it felt like there was either no vacuum help, or too much. I had a theory that something was plumbed wrong, and it was somehow fighting itself.
Great job on the car! I look forward to seeing more.
sjd
