You should also consider the whole drivetrain package and what you consider fun. A 383 with a huge cam, 4-spd and 3:23 gears, or an automatic with a too tight or too loose convertor can turn into more of a chore than fun.
Absolutely.... when running it hard I'd drop it into 1st and put the pedal to the floor slapping the shifter at 6,000 rpm for 2nd and 3rd. A good ratchet shifter that prevents shifting more than one gear at a time while locking out reverse makes it even more fun.For the guys that have automatic's have you used the shifter to run thru the gears like a std?
I've switched to a 6 speed standard since then but just had a B&M Quicksilver mounted in the console. I really like the Quicksilver for it's simplicity and ease of use, instead of pulling triggers or levers for the lockout you just lift on the shifter knob. I'll dig around and see if I can find a pic.Now THIS is what I like! Got a pic of your set up?
Also, love your T. Jefferson quote!
That's why pushbuttons are so cool!Of course, but my Bee is a column shift and sometimes I've gone from 1st to 3rd, or 2nd to N. A reverse manual valve body would fix that, but then everything is a shift, and if you forget to downshift to 1st at a stop light, you're starting in 3rd. DOH!!
You CAN push start an early cable shift 727!Maybe you will find an auto car you like with no drive train and build your own?
Good people here in that case.
http://www.brewersperformance.com/
One thing about a manual car. If you starter fails, just have your buddy start pushing.
Try that with a voodoo science slush box.
I would vote for manual for your purpose.
That being said, my daily driver is a 904 lock up and I like that.
On the positive side, if you do go auto, you will have one of the best ones ever made.
