70 Hemi Superbird Restoration..................errr.....scratch that........
Getting comfortable when welding is the most important part for perfect welds. I see you have that figured out!
Made very little progress as my wife's class reunion ate the weekend. I did get some parts stripped off the other car to make sure they fit on this one. Now I've got to order some bending dies for 7/8 and 1" to make upper and lower control arms.
Front suspension in a box, just add a rack and A-arms!
I made the template for the lower shock mount. Now I just need to cut them.
Thought you'd like this. I was at St. Louis over the weekend for the NHRA race.
Sweet! I had to weigh my options....go to the NHRA race in St. Louis or go to my wife's reunion so you know where I went! Not racing!
It was plenty hot. People dropping like flies from heat. Farmers Daytona went 2 rnds, white 70 didn't make the field which was 2nd quickest all time with 5.98 bump. 32 cars showed up.
Plasma or laser, looks like plasma.
It's plasma. I know another guy with a laser, but he usually wants a CAD file and then I have to wait until he runs a batch of that thickness material and hope he has room to nest it in. The plasma just needs a little edge clean up here and there and it's good enough. The hole quality isn't near as good as laser either, but it will work fine. I cut four as I'm going to do two sets of LCAs. One set with lower bushings like the Alterktion uses and one with spherical rod ends. All my Ford friends run rod ends on their aftermarket uppers and lowers.
Wow just found this thread, your doing awesome work! So after watching all the live feeds from Drag Week a couple weeks ago I can't wait to see it in action.
What class will it run in? I'm gonna guess Street Race big block power adder?
Thanks. The one rule keeping me out of that class is the No Funny Car Cage rule so I get bumped to Super Street Big Block power adder.
