I installed my AMD front pan and the rear foot pans a few months ago, pretty mutch just get er done. The pans sat in place without mutch force having to be applied, Starting at the firewall, I just used a few self tapping screws to gradually bring the frame braces and pan together welding a few spot welds here and there to mate the two together. I used some vice grips or C clamps as needed. I just completed my rear underseat pan and found it to be the only challenging pan, as I also replaced my inner rear fender wells. Starting on my Trunk Pan when it arrives next weekend. If you supported the car well, I cant see anything shifting, mine fit very well I did not have to trim anything, I had used spot weld cutters to cut out the old welds on the floor, in a few of those spots I inadvertently cut a few holes into the floor bracing, I used a few nut, bolt and washers to pull the pan down in those spots before spot welding. I'm in trouble if those measurements are needed. Good Luck these pans are mutch easier than one would think. I forgot that ten pound hammer worked well at times LOL
