Texas charger 73
I just put a rebuilt (about I months ago) 904 transmission in my charger with a 2800 stall. It will go through all the gears on column except low. You have to slam colum to get it in low(sloppy linkage) . My problem is it will go I reverse and drive correct and when you get it in low it will drive correct, but when you out it I drive it seems like it's taking off in second d or third. It revs to almost 25-2600 till it starts moving. I have been told it could be a stuck governor or it could be the valve body (I put a B&m shift kit in, street/strip kit). Can I pull tailshaft with transmission in car still? I just put transmission in 2 weeks ago. Should I clean the Governor or upgrade to a steel one? I just want to drive my car and it's frustrating me.
