Mike Gaines
- 7:37 AM
- Apr 17, 2014
- Ahwahnee, (Fresno) California
I know a lot of guys installed their transbrakes WITHOUT upgrading the stock drum to a steel (or aluminum) billet drum....but those guys all did have a good SPRAG.
I am told that the stock sprag breaking is what then causes the stock drum to then explode.
plus...I don't know if the sprag breaking has anything to do with the transbrake being used.
My transmission does currently have a top of the line sprag.
I really need a transbrake to be competitive as 95% of all the guys I come up against have transbrakes.
My budget is kinda tight and I don't know if just the transbrake valve body ($650) is ok to install (with a good sprag) or do you really need to spend the extra $650 for the steel billet drum
Also does using the transbrake have anything to do with causing the sprag to break ?
Give me some opinions on if this is just stupid or can you get by without spending the $650 for a billet drum as long as the transmission has an upgraded top of the line sprag.
