thoughts on this hyd roller cam
moparjohnny
11:53 AM
ga
i have a 383 eng,69 roadrunner,thinking about this cam here are specs 282/288,520 intake,530 ex, 112 lobe sep angle.the cam is howards retro fit.pretty much stock heads,headers,, 4speed,3.55 gears.750 holley. thanks
I'd like to know the duration @ .050 & your tire size. Not crazy about the 112.
that would probably be just fine.
if you buy one look at it real close when you get it.
Howards makes Hughes Engines roller cams, i order one last year and the fuel pump part of the cam was miss cut, i sent it back for a new one. but it took so long to get, i ended up buying a Lunati Voodoo roller, and its pretty awesome. sold the Howards/Hughes cam on the forums.
thanks,what would that look like on cam so i can tell something is off? thanks,which lunati did you buy?
