- 8:41 AM
- Dec 4, 2009
- Pasadena, Texas
How about the weight on the new pistons. Probably not the same as the ones you have now.....
I would buy those pistons if they are in good shape. Check your cyl bore first to make sure the pistons are the same size or larger. Get some closed chamber heads at 79 cc, use a .020" steel shim head gasket, and you will be at 9.7 to 1. Go to 77 cc head volume, deck the block .010, then you will be at 10.14 to 1. That's what I would shoot for. You will then have .037" of squish which is perfect! Reduces pinging chances, and gives the motor really crisp throttle response. Cutting the block .010 isn't going to change port or bolt alignment enough to cause any problems. You will have a good strong running motor with good throttle response. Set the timing at 20 degrees initial, 38 total. I recommend a Street Dominator intake, or a Performer RPM. A Torker or similar manifold may work good too.I've found a set of nice used pistons with 1.900 compression distance. That takes me up to 0.028 deck clearance!
The hunt for a set of 915's keeps going. A guy in Norway said he had a couple, I will hear from him soon..
I was thinking of a 2-plane manifold. Mostly for driveability on the lower rpm. Looking at a Edelbrock DP4BI would buy those pistons if they are in good shape. Check your cyl bore first to make sure the pistons are the same size or larger. Get some closed chamber heads at 79 cc, use a .020" steel shim head gasket, and you will be at 9.7 to 1. Go to 77 cc head volume, deck the block .010, then you will be at 10.14 to 1. That's what I would shoot for. You will then have .037" of squish which is perfect! Reduces pinging chances, and gives the motor really crisp throttle response. Cutting the block .010 isn't going to change port or bolt alignment enough to cause any problems. You will have a good strong running motor with good throttle response. Set the timing at 20 degrees initial, 38 total. I recommend a Street Dominator intake, or a Performer RPM. A Torker or similar manifold may work good too.
I still recommend doing a mock up at the very least. I've had intakes that didn't fit all that well with stock stuff....especially aftermarket ones.I would buy those pistons if they are in good shape. Check your cyl bore first to make sure the pistons are the same size or larger. Get some closed chamber heads at 79 cc, use a .020" steel shim head gasket, and you will be at 9.7 to 1. Go to 77 cc head volume, deck the block .010, then you will be at 10.14 to 1. That's what I would shoot for. You will then have .037" of squish which is perfect! Reduces pinging chances, and gives the motor really crisp throttle response. Cutting the block .010 isn't going to change port or bolt alignment enough to cause any problems. You will have a good strong running motor with good throttle response. Set the timing at 20 degrees initial, 38 total. I recommend a Street Dominator intake, or a Performer RPM. A Torker or similar manifold may work good too.
Don't think I'll touch the decks.. With the taller pistons, and new gaskets (any recommendations? Would like to come close to .020) I'll improve the C/R quite a bit. 9.01:1 due to the calculator. That's a number I'm quite happy with.I still recommend doing a mock up at the very least. I've had intakes that didn't fit all that well with stock stuff....especially aftermarket ones.
You might think about, at the very least, get the machine shop to check the block deck surface. Unless it's real good, chance it needs a wipe to make it true. I only needed .005" on both my deck surfaces, and heads, to get them flat and true centerline.I've found a set of nice used pistons with 1.900 compression distance. That takes me up to 0.028 deck clearance!
Yes, maybe I should ask them to check the decks at least..You might think about, at the very least, get the machine shop to check the block deck surface. Unless it's real good, chance it needs a wipe to make it true. I only needed .005" on both my deck surfaces, and heads, to get them flat and true centerline.
Once that's done, with those pistons, you can set the CR you want by the head gasket thickness...up or down.
I guess there gaskets puts higher demands on the deck/head surfaces... I should talk to my machine shop about this..I would use the beaded steel head gasket from Mopar Perf, or Mr Gasket. Thickness is .020", and I've never had a problem with one. Part # P4286754. (Mopar Performance #) Only $24.97/pair from Summit.
These motors have very few (if any) head gasket probs when assembled correctly. This includes running a tap thru the threads on the block, and a few drops of oil on the bolt threads helps. Also I start at 30 ft lbs of torque, then go thru the tightening sequence, raising the torque 10 lbs each time until I get to the recommended torque of 70 ft lbs for iron heads. Not sure what alum heads get, I think it's 60 ft lbs.I guess there gaskets puts higher demands on the deck/head surfaces... I should talk to my machine shop about this..
I found i guy pretty close to Gothenburg that had a couple of 0.020 gaskets. I still think my budget won't allow a set of new heads at this time. So I think I have to settle with 9.01:1 CR. Although I really would like to try and port my 906 heads a little bit. Starting with the intake-windows. I have to do some research on how to go on from there... Don't wanna ruin everything..I found out the Eddy Perf RPM heads also need 70 ft lbs of torque. Start at 40, then 55, final torque of 70 ft lbs. So what did you finally decide on as far as a cyl head and gasket goes?
