4 speed trans with automatic radiator
moparjohnny
7:14 AM
ga
do i need to block off the two lower trans cooling lines ports or if they can be left untapped? thanks
Can't tell from your post I assume your running a separate cooler? Those lines supply lube to trans, you probably known that.
