Glenwood
- 7:41 PM
- Jun 19, 2015
- Kawartha Lakes, Ontario
So, if the main bearings showed little wear but were original, should they get changed due to age? Just curious on deciding factors.
For example, my '73 413 block had little wear on the bearings or cylinders with no ridge at all, but the block has been sitting around for quite some time. The builder examined it after I did finding the block, journals, crank, etc., in good shape but recommended align boring anyway. This was all done btw, just wondering what happens to a block that sits for many years. He talked about possible core shifting, which gets corrected by boring the cylinders?
Also when ordering main and/or rod bearings, how is the correct stock parts ordered when the sizes can vary, such as a block that is stamped with a maltese cross or X? Don's book doesn't really go into these details.
