Wish I had more found the image on the net.Nice teaser shot. How about some more?
Depending on the make, the brackets were either welded on or bolted on. Dodge was bolted, Plymouth was welded, or vice-versa, so please verify. I honestly can’t remember anymore.
Thanks for the info. guys. Never thought of Crossram Connection.Plymouth welded,I have a picture of the exact location,if I can find it I'll post it.
Thank you very much.Hope you can figure this out,first and second give measurements from driver side door sill and front of floor pan,third picture is front passenger side sill to bracket mounting.If you relate the bracket mounting to the floor pan ribs,it will work out.Notice the bracket mounting is angled,that is how the holes need to be drilled.
View attachment 386875 View attachment 386876 View attachment 386877
63 dodges i had where welded 63 plymouths i had where boltedThank you very much.
