Max Wedge e-brake
Auto Teach
10:30 PM
New England
Does anyone one reproduce the extra brackets on the floor pan for the brake cables on a max wedge car?
Try Kramer Automotive for any Max Wedge Stuff. Jim Kramer is a worth of knowledge on Maxie & Hemi early "B's".
Depending on the make, the brackets were either welded on or bolted on. Dodge was bolted, Plymouth was welded, or vice-versa, so please verify. I honestly can’t remember anymore.
Crossram connection has everything MW including those ..as 62max commented above
Plymouth welded,I have a picture of the exact location,if I can find it I'll post it.
Hope you can figure this out,first and second give measurements from driver side door sill and front of floor pan,third picture is front passenger side sill to bracket mounting.If you relate the bracket mounting to the floor pan ribs,it will work out.Notice the bracket mounting is angled,that is how the holes need to be drilled.
